Replace video in a camera view item
Version2026 R2
LanguageEnglish
If you have a view open, and something happens that is not in the view, you can temporarily replace video from one camera with another.
  1. Select the camera view item to replace.
  2. From the camera toolbar, select the relevant camera or use a numeric keypad shortcut, press /+<camera shortcut number>+Enter.
Note
If you want to change your view permanently, on the workspace toolbar, select Setup.
