Removing video restrictions
Version2026 R2
LanguageEnglish
When a restriction is removed, the underlying video material (live and recorded) becomes available again for viewing by operators as usual.
You can only edit or remove restrictions on cameras located on the site you are currently logged on to.
Removing a restriction will not change the status of any applied evidence locks on the same video sequence. If a video sequence has been locked, the evidence lock on the video must still be deleted if the video is to be deleted.
