Media player format settings—combined file
Version2026 R2
LanguageEnglish
Choose the media player format Combined file to export several video or audio sequences from various cameras combined into one file that the recipient can view or listen to on computers with a standard media player installed.
General settings
Name
Description
Codec
Displays the codec of the exported video.
Content
Choose video, audio, or both.
Compression quality
The compression quality determines the size of the file you export. The higher the compression quality you choose for the encoder to apply, the bigger the file size you get.
Resolution
The option you select determines the maximum resolution of the output file.
Because multiple video sequences are combined into one video file, the resolution and aspect ratio of individual cameras can change during playback, but only to a lower resolution than you’ve selected.
Frames per second (FPS)
Frames per second indicate the number of frames shown per second. The higher the number of frames, the bigger the file size you get.
Advanced settings
Name
Description
Format and layout type
Format
Export video in the MKV format or in the MP4 format.
Layout type
  • Single camera view: The exported file plays back the sequences according to the order you have arranged the cameras in the export list. Before you start an export, use the arrows to reorder the files in the export list.
    You can reorder your export list using the arrow to the left of each video sequence
  • Adaptive view: The exported file plays back the video in the order it was recorded. If video sequences were recorded at the same time, they are also played back at the same time.
Resolution settings
To control the output resolution and improve the export file's compatibility with mobile devices, you can use these options:
  • Prevent upscaling: To prevent video from low-resolution cameras from being scaled up and thereby looking grainy, you can select this option to avoid increasing output resolution beyond its original size.
  • Add padding: Combining video sequences from different cameras into one file can change the resolution during playback which some media players do not support. This option adds padding around the video to ensure that the resolution is the same throughout.
Additional information
  • Include timestamps: Displays the video’s time of recording as an overlay on the video.
  • Include camera names: Displays the camera name as an overlay on the video.
