Keyboard settings
Version2026 R2
LanguageEnglish
Keyboard settings let you assign your own shortcut key combinations to particular actions in the XProtect Smart Client. The XProtect Smart Client also features a small number of default keyboard shortcuts immediately ready for use. See Default keyboard shortcuts.
Name
Description
Press shortcut key
Enter the key combination you want to use as a shortcut to a particular action.
Use new shortcut in
Select to define how you want to apply the shortcut:
  • Global: On all of the XProtect Smart Client tabs
  • Playback mode: Only on tabs with views
  • Live mode: Only on tabs with views
  • Setup mode: Only in setup mode
Categories and Commands
Select a command category and then select one of the associated commands. If you want all your views listed to allow you to create keyboard shortcuts for individual views, select the Views.All category.
Note
Some commands only work when the keyboard shortcut is used in certain contexts. For example, a keyboard shortcut with a PTZ-related command will only work when using a PTZ camera.
Parameter
If relevant, specify a parameter for the command or action. For example, if you want to specify the window and view item for the Copy the selected camera view item command, enter 2;1 to have the camera copied to the floating window (window 2), in the first view item (view item 1).
