Go back to previous locations on a smart map
Version2026 R2
LanguageEnglish
When you move from one location on the smart map to another, XProtect Smart Client keeps a history of your visits. The history records locations that you both pan/zoom to and also click on. It does not record locations if you only pan or zoom to them.
When you backtrack, the location you just left is removed from the history. It includes only forward movements and is cleared when you select another view.
  • Select SC_MapS_GoToLastLocation_icon.png Back to go back to the previous location. Click multiple times to go further back.
Go to locations on your smart map in XProtect Smart Client.
