Exporting video, audio, and still images
Version2026 R2
LanguageEnglish
If you need to document an incident that has occurred, for example, to provide legal evidence, you can export a video sequence from XProtect Smart Client. If you need to prove that the video evidence has not been tampered with, you can export it in the XProtect format. If you use this format, you can "lock" the evidence behind a digital signature that verifies the authenticity of the exported video.
You export video and associated audio in different formats. Depending on your VMS system, you can also export still images and other types of data that might be available.
