Evidence lock settings
Version2026 R2
LanguageEnglish
Name
Description
Headline
The headline of the evidence lock.
Description
A description of the evidence lock.
Interval start
Adjust the start date and time for the video sequences you want to protect.
Interval end
Adjust the end date and time for the video sequences you want to protect.
Keep evidence lock for
Specify for how long you want to keep the evidence protected.
Depending on your user permissions, you have the following options: hour(s), day(s), week(s), month(s), year(s), indefinite, or user-defined.
If you select User-defined, click the calendar button to select a date and then adjust the time manually.
When done, the date and time for when the evidence lock expires is shown.
Select camera
Click to select more cameras to include in the evidence lock.
Create playback video restriction
Create a playback video restriction on the same video sequence you are creating an evidence lock for.
The video restriction is not connected to the evidence lock and must be edited, maintained and removed manually.
Remove/Remove all
Click to remove one selected camera or all cameras from the evidence lock.
