Creating views
Version2026 R2
LanguageEnglish
Creating views involves a series of overall steps that you typically complete in the following order:
  1. If want to save a new view under a new group, you create the group first. See Create a view group.
  2. You create the view itself. See Create a view.
    Note
    Consider if copying and adjusting an existing view is faster than creating a new one. See Copy a view or view group.
  3. You add content to the view. See Adding content to views.
  4. (optional) You assign shortcut numbers to the view to enable users to switch between views quickly. See Assign a shortcut number to a view.
  5. (optional) You add overlay buttons to the different camera view items in a view to enable the users to trigger actions directly from the views. See Add an overlay button to a camera view item.
