Create a temporary view through search
Version2026 R2
LanguageEnglish
You can quickly create a temporary view by searching for cameras.
  1. On the Views tab, use the Search views and cameras field to search for cameras.
    Additionally, you can select SC_Views_Keywords_icon.png next to the search field to use common search keywords.
  2. Select a view from the search results.
  3. Select one or more cameras (use Ctrl or Shift to select mulitple cameras) and then press Enter to create the temporary view.
If you want to save your view, on the workspace toolbar, select Setup.
