Change the appearance of map elements
Version2026 R2
LanguageEnglish
You can change the color of texts, backgrounds, hot zones, etc. on maps to differentiate map elements from each other.
  1. In setup mode, right-click the map and select Toolbox.
  2. Select the element that you want to change.
  3. In the toolbox, select the color fill tool SC_Map_Fill_icon.png. This will open the Color selection window.
    Tip
    Use the color picker tool SC_Map_SelectColor_icon.png to use an existing color from the map.
  4. Only relevant for text elements: Select whether you want the color change to apply to text or background.
  5. Select the color from the color palette—you can see a preview of the selected color in the EXAMPLE box.
  6. Click the map element to fill it with the new color.
