Change OpenStreetMap tile server
Version2026 R2
LanguageEnglish
Steps:
  1. Specify alternative tile server for the smart map.
  2. In the left section, click Smart map.
  3. In the OpenStreetMap server field, do one of the following:
    • Enter the server address. If the field is grayed out, it has been locked server-side
    • To use the server specified server-side, if any, select the Follow server check box
  4. Click Close. Next time you load your smart map, it will use the OpenStreetMap server that you have specified.
Important
If no server address is specified, or the server address is invalid, then OpenStreetMap is not available as a geographic background.
