Adjust position, size, or alignment of custom overlay
Version2026 R2
LanguageEnglish
You can move an overlay to a different place on the map, make it larger or smaller, and rotate it. For example, this is useful if your overlay is not geo-referenced, or the overlay is geo-referenced but for some reason does not align exactly with the geographic background.
Steps:
  1. Select the view that contains the smart map, and then click Setup.
  2. Right-click the overlay, and select Edit position.
  3. To resize or rotate the overlay:
    • Click and drag a corner handle
    • To rotate the overlay around a specific point, move the pivot point to that place on the map. Then click and drag a corner handle
  4. To move the overlay on the map, click and drag the overlay.
  5. To save the change, click Save.
