Add sticky notes to camera view items
Version2026 R2
LanguageEnglish
Sticky Notes let you add and share short camera-specific information directly on live video in XProtect Smart Client. You can use Sticky Notes to provide important information, instructions, or warnings to your colleagues who view the same camera. This helps everyone stay informed when monitoring incidents and activities.
Sticky notes are available only on cameras that support this feature, and each camera can have one note. You can add and view sticky notes in live mode, but they aren’t available during playback.
To add a sticky note:
  1. In XProtect Smart Client, open a view that contains the camera you want to add a sticky note to.
  2. Select the Sticky Note icon SC_CameraToolbar_StickyNote_icon.png, enter your note, and select the relevant category. You can enter up to 256 characters in a note.
  3. Select Add.
The sticky note now appears at the top of the camera view item in live mode. To edit or delete the note, select Edit MobC_Android_Edit_icon_I.png.
Note
- If two users edit the same sticky note at the same time, the most recent change is saved.
- If an administrator disables a category, existing notes in that category remain available but appear as No category.
