Add a camera to a view
Version2026 R2
LanguageEnglish
To view video from a camera, you must first add the camera to a view.
  1. On the System overview pane, select a server SC_SystemOverview_Server_icon.png and expand the folders to find the relevant cameras.
    Note
    If a server has a red icon, it is unavailable, and its cameras are not listed.
  2. Select a camera and drag it to a view item, or select a folder to add all cameras within it to your view.
    Important
    Check permissions for shared views: Ensure that users have permission to view video from the cameras in your shared view. If in doubt, contact your system administrator.
  3. On the Properties pane, specify camera properties (for example, live stream and PTZ click mode). See Camera settings overview.
