System Monitor tab with Milestone Federated Architecture
If you run Milestone Federated Architecture™, the System Monitor tab is divided into two parts:
One pane displays a hierarchical tree-structure representing your federated architecture
The other pane is a browser-based area with relevant system data for the selected server
Click any server in the site pane to see its system data.
If you move away from the tab or log out of the system and come back, the System Monitor tab remembers which server is selected in your federated architecture and continues to display system data from this server.
You can drag the System Monitor tab to an independent window to monitor multiple servers.
