Specify an end position for a patrolling profile
You can specify that the camera should move to a specific position when patrolling ends. You do that by selecting an end position on the patrolling profile.
Select the patrolling profile in the Patrolling profile list.
Below On finish, go to, select one of the presets from the drop-down list as the end position.
Note
You can select any of the camera's PTZ presets as the end position, you are not limited to the presets used in the patrolling profile. You can also choose not to specify an end position at all, but to keep the default setting: No end position.
