Show bounding boxes around important objects
Select the relevant view and the camera view item.
On the Properties pane, under Display settings, select Show bounding box layer.
Select Bounding box providers to enable the metadata device. If there is only one provider, it is automatically selected.
Bounding boxes also appear when you:
Export video in the XProtect format. See Export settings.
Print still images. See Printing or creating surveillance reports.
If bounding boxes don’t appear, see Troubleshooting: No video or bounding boxes.
