Motion search thresholds
When you search for motion in selected areas of a camera, you can adjust the motion threshold. The motion threshold determines how sensitive the motion search mechanism is:
The higher the threshold, the more motion is required to activate motion detection. Likely, this will produce fewer search results
The lower the threshold, the less motion is required to activate motion detection. Likely, this will produce more search results
