Manually activate events
You can manually activate an event. There is no confirmation when you have activated an event. The list of events you can select is grouped by event server, and the camera or device that the event is associated with.
In live mode, expand the Event pane, then click Activate.
Note
Global events appear under the relevant event server. If an event server is listed with a red icon, it is unavailable and you cannot activate events on it.
