Investigate your search results
Version2026r1
LanguageEnglish
There are different ways of investigating incidents that you have found on the Search tab:
  • Open the search result in a detached window in playback mode. See also Open search results in detached windows.
  • Open the search result in a detailed view. Do one of the following:
    • In the list of search results, double-click the search result to view it in full-screen mode. Double-click again to return to the list of search results.
    • If you’re previewing your search result in the preview area, double-click inside the video image. The search result opens in full-screen mode. Double-click again to return to the preview area.
