Get statistics on alarms
Get statistical data about the alarms triggered in your XProtect VMS system over the:
Last 24 hours
Last 7 days
Last 30 days
Last 6 months
Last year
The Alarm Report window shows two graphs that display the number of alarms filtered by categories, for example Priority or State, allowing you to compare the two graphs side by side.
Steps:
In the Alarm List, click the Reports button. A window appears.
Above the graphs, select the timespan, for example Last 24 hours.
In the Select report list, select one of these categories:
Category
State
Priority
Reasons for closing
Site
Response time
For each graph, select a sub-filter. For example if you selected State, you can select New in the first graph and In progress in the second. The graphs are populated.
To print the graphs as a PDF report, click
