Functions settings
The Functions settings let you specify the functions (for example, playback in live mode) that you want to display on a particular XProtect Smart Client tab.
The Mode column displays where the pane is available, the Function column displays the name of the function, and the Setting column lets you specify whether or not you want the pane to be available.
If available, the Follow server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings are server-controlled, in which case configuration on the server decides whether or not you can override the settings.
Name | Description |
Live > Camera playback | The ability to play back recorded video from individual cameras while in live mode. |
Live > Overlay buttons | The ability to view and use overlay buttons in live mode for activating speakers, events, output, moving PTZ cameras, clearing indicators from cameras, etc. |
Live and Playback > Bookmark | Select whether you want to add quick or detailed bookmarks from the view item toolbar or through ready-made overlay buttons in live or playback mode. Enabling or disabling this option in playback mode controls whether or not the corresponding button is enabled on the Search tab. NoteDepending on your user permissions, access to adding bookmarks from some cameras may be restricted. |
Live and Playback > Print | The ability to print in live or playback mode. Enabling or disabling this option in playback mode controls whether or not the corresponding button is enabled on the Search tab. |
Live and Playback > Bounding boxes | The ability to show bounding boxes on live video in live mode or on recorded video in playback mode on all cameras. Bounding boxes are used for, for example, tracking objects. NoteThe bounding box feature is only available if connected to certain surveillance systems and to cameras that support metadata. Depending on your user permissions, access to bounding boxes from some cameras may be restricted. |
Playback > Independent playback | The ability to play back recorded video from individual cameras independently in playback mode, where all cameras in a view otherwise by default display recordings from the same point in time (the playback time). |
Setup > Edit overlay buttons | The ability to add new or edit existing overlay buttons in setup mode. To add overlay buttons, the Overlay buttons list must be set to Available (you manage this on the Panes tab in the Settings window). |
Setup > Edit video buffering | The ability to edit video buffering is part of the camera properties in setup mode. To edit video buffering, the Setup tab's Properties pane must also be made available (you manage this on the Settings window's Panes tab). |
