Evidence lock settings
Name | Description |
Headline | The headline of the evidence lock. |
Description | A description of the evidence lock. |
Interval start | Adjust the start date and time for the video sequences you want to protect. |
Interval end | Adjust the end date and time for the video sequences you want to protect. |
Keep evidence lock for | Specify for how long you want to keep the evidence protected. Depending on your user permissions, you have the following options: hour(s), day(s), week(s), month(s), year(s), indefinite, or user-defined. If you select User-defined, click the calendar button to select a date and then adjust the time manually. When done, the date and time for when the evidence lock expires is shown. |
Select camera | Click to select more cameras to include in the evidence lock. |
Create playback video restriction | Create a playback video restriction on the same video sequence you are creating an evidence lock for. The video restriction is not connected to the evidence lock and must be edited, maintained and removed manually. |
Remove/Remove all | Click to remove one selected camera or all cameras from the evidence lock. |
