Edit bookmarks from search results
You can edit the details of bookmarks in your system, for example the time span, headline, and description. You can also edit multiple bookmarks at the same time.
On the Search tab, find the bookmarks that you want to edit. When you perform the search, make sure that you have selected Search for > Bookmarks.
For each bookmark that you want to edit, hover over it and select the blue check box
.In the blue action bar, click
. A window appears.
Select the search results one by one to edit the details, for example time span, headline, and description.
Click OK to save your changes. A progress bar informs you when the changes are saved.
Note
If XProtect Smart Wall is set up in your system, click Display on Smart Wall to send the bookmarks a video wall.
