Delete buildings on Smart Map
If a building is no longer needed, you can delete it. Next time someone logs into XProtect Smart Client or reloads, the building is gone.
Steps:
Open the smart map.
On the workspace toolbar, select Setup.
Do one of the following:
Right-click the building and select Delete
Select the building, and press DELETE on your keyboard
Tip
An alternate way of deleting a building: In the
Manage default settings, scroll down to the Buildings section, hover on the building, click Delete and then Save.
