Create a live restriction
In Live mode, select the camera view you want to restrict access to and click Video restrictions > Create to open Create live restriction. All cameras in the selected view are added by default to the restriction.
In the Create live restriction dialog > Interval start field, set the start time of the restriction.
The default value of the restriction start time is 5 minutes back.
If necessary, in the right half of the Create live restriction dialog, click Add camera and select additional cameras to add to the restriction. You can also remove any cameras that should not be restricted.
Click Create live restriction to open the Create live restriction dialog. When the restriction has been created, click Close to close the dialog.
You can click Details to get a more detailed overview of the creation process.
