Contributing to investigations and solution of incidents
When you view live or recorded videos, you can play a key role in securing evidence for investigators and sharing information with colleagues when incidents occur. Even if your system administrator has set up the XProtect VMS to record automatically, you might need to manually start recording to capture evidence in certain cases.
You can share views showing the incident, the camera name, bookmark the incident, or send video to a video wall or a Matrix view item.
