Allow HTTP connections
If your XProtect VMS system doesn’t have a certificate installed, you can’t connect with the newest available security model in XProtect. The security model is based on the HTTPS network protocol.
To allow HTTP connections, select Remember my choice. Do not show this message again.
Note
If your XProtect Smart Client is connected to a XProtect VMS system or a federated site using the older security model (HTTP), a Not secure information message is shown to the left of the global toolbar.
See also No longer allow HTTP connections.
