Add a hotspot to a view
A hotspot view item displays video feeds in a higher resolution enabling users to see details more clearly while also saving bandwidth on your remote connections.
There are two types of hotspots:
Global hotspots: Displays the selected camera regardless of which view the camera is in.
Local hotspots: Displays only the selected camera if the camera is within the same view.
Tip
It’s recommended to add a hotspot to the largest view item, such as the large view item in a 1+7 view.
On the System overview pane, drag the Hotspot item to the relevant view item.
(optional) On the Properties pane, modify the properties for the hotspot.
