Viewing exported video in default views
Version2025r3
LanguageEnglish
When you open exported video, the video is, by default, opened in a default view with a maximum of 25 view items. Exported video from 1-25 cameras is in a default view shown in at least as many view items as the number of cameras. However, if you have received exported video from more than 25 cameras, the exported video is displayed in several default views. For example, exported video from 100 cameras is shown in four default views.
When you play back the exported video in default views, most view items are empty at different times because even if you have received 10 minutes of video, there are, for example, only 2 minutes of video from each camera, leaving each view item empty for 8 minutes.
If the export project has video from many cameras, seeing all details in the video is difficult because each view item has limited space. Also, if the video is shown in several views, it is challenging to gain an overview.
