View exported video
Version2025r3
LanguageEnglish
To view the exported video immediately after creating it:
  1. In the upper-right corner of XProtect Smart Client, select Export details.
    In the Export details window > Export location field, a link shows the location of the output folder.
  2. Click the link to open the output folder and to access the exported files.
    The Export details window. The export location is a hyperlink. When you click the hyperlink, the folder that contains the export files opens.
If you exported video at a previous point in time:
  1. Go to the folder where you store exports. The default location is C:\Users\[username]\Documents\Milestone\Video Export. You can check the folder location in the Create export window > Export destination field. This works only if you always use the same export destination.
  2. Depending on the output format, open the relevant folder and double-click the video file or still image. If the format is XProtect format, double-click the Smart Client – Player file with the .exe extension.
