Types of formats for exports
Version2025r3
LanguageEnglish
XProtect Smart Client enables you to export in one or more of the following formats:
Format
Description
XProtect format
Use the XProtect format to include the XProtect Smart Client – Player along with the export. The XProtect Smart Client – Player is the only media player that can play this format. To verify that the exported evidence has not been tampered with, select Export settings > XProtect format > Include digital signature. This setting enables the Verify signatures button in the XProtect Smart Client – Player.
Media player format
Use a format that does not require you to know how to use XProtect, and that most media players can play. You only need to have a media player installed to play this format.
There are two ways to export in media player format:
Still images
Export a still image file from each frame for the time period you have selected.
