Timeline settings
Version2025r3
LanguageEnglish
The Timeline settings let you specify the general settings for the timelines in XProtect Smart Client.
If available, the Follow server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings are server-controlled, in which case, configuration on the server decides whether you can override the settings.
Name
Description
Incoming audio
Outgoing audio
Additional data
Additional markers
Bookmarks
Motion indication
All cameras timeline
See Configure what to show on the timeline tracks.
Playback
See Configure playback of gaps between recordings.
Hide the timeline during inactivity
Hide the timeline in Smart Wall views
See Hide the main timeline.
