Specify default settings for smart map
Version2025r3
LanguageEnglish
After adding a smart map to a view, and you have added the overlays, cameras, and links, you can specify the default settings for the custom overlays. You can also delete custom overlays to clean up.
  1. Click Setup.
  2. Click SC_MapS_ManageDefaultSettings_icon.png Manage default settings.
  3. Do any of the following:
    • To show or hide an overlay, select or clear the check box
    • To rearrange the order, use the drag handle in front of the overlay to drag it to a new position in the list. Layers are ordered from top to bottom in the list
    • To delete an overlay, hover the pointer over the overlay, and then click Delete
  4. Click Save.
