Show or hide layers on a smart map
Version2025r3
LanguageEnglish
You can show or hide layers on your smart map, including the geographical background. This feature is useful when you want to focus on a specific element or simplify the display on the smart map.
  1. Select your smart map.
  2. On the toolbar, select SC_Map_ShowHideLayers_icon.png Show or hide layers and custom overlays.
  3. To show or hide the layers with System elements and Custom overlays, select or clear the check boxes.
    Note
    Hiding the System elements layer mutes all microphones until you show the layer again. Manually muted microphones remain muted.
  4. To hide the Geographic background layer, select None.
    The geo-references still apply to the smart map even if the geographic background layer is hidden.
