Show bounding boxes around important objects
Version2025r3
LanguageEnglish
  1. Select the relevant view and the camera view item.
  2. On the Properties pane, under Display settings, select Show bounding box layer.
  3. Select Bounding box providers to enable the metadata device. If there is only one provider, it is automatically selected.
Bounding boxes also appear when you:
If bounding boxes don’t appear, see Troubleshooting: No video or bounding boxes.
