Select or change device icon
Version2025r3
LanguageEnglish
You can choose a device icon that matches the type of device that you are using.
  1. Select the view that contains the smart map that you want to work with.
  2. Click Setup, and then double-click the device icon on the map.
  3. Click Pick icon, and then select the icon for the device.
  4. Click Setup again to save the change.
