Search for multiple criteria in video sequences
Version2025r3
LanguageEnglish
You can search for a combination of criteria in video sequences if you have XProtect Corporate or XProtect Expert.
When you have found the relevant video sequences you can, for example, send the video sequences for export, bookmark the video sequences or other.
  1. Open the Search tab.
  2. On the Start and End time filter selector, select the arrow to select a predefined time span, or define your own Custom interval.
    Set the timespan while configuring your search in XProtect Smart Client.
  3. On the Selected cameras list filter selector, use the Select camera search field to find cameras or views and then select the cameras which video sequences you want to search in.
  4. Select Search for to select one or more search categories.
    Specify what to search for in XProtect Smart Client.
  5. For each search category that you have added, select Add or remove filters to refine results SC_Search_Filter_icon.png to refine your search. See also FAQ: searching.
    Search based on motion in XProtect Smart Client.
  6. To preview the video of a search result, select the search result and, in the preview pane, select Play forward SC_Search_Preview_Play_icon.png.
    Preview search results in XProtect Smart Client.
    Tip
    To play back the video sequence in full-screen mode, double-click the search result.
  7. To make the action bar appear, hover over the search results, one by one, and select the blue check box that appears.
    Search result with the blue check box selected in XProtect Smart Client.
    The blue action bar appears:
    Blue action bar on the Search tab in XProtect Smart Client.
