Search for bookmarks
Version2025r3
LanguageEnglish
You can find incidents that are bookmarked by you or others for any number of cameras.
  1. Select the cameras that you want to include in your search.
  2. Click Search for > Bookmark > New search. If the database has any bookmarked recordings, they appear as thumbnail images in the search results pane.
  3. Optionally, enter a keyword to filter the search results. The keyword can be:
    • The full Bookmark ID, for example no.000004
    • Who the bookmark was added by, for example site\user2
    • Any text that appears in the Headline or in the Description
    Note
    By default, the system will search for the keyword both in the Headline and in the Description. Use Search for keyword in to change that.
  4. To preview the video sequence and bookmark details, select a search result and play back the video in the preview pane on the right-hand side.
    Preview bookmark in XProtect Smart Client.
  5. To view the recording in full-screen mode, double-click the search result.
  6. To perform other actions, for example editing the bookmark, hover over the search result and select the check box SC_SearchResult_CheckBox.png. The action bar is displayed.
