Scripting HTML page for navigation
Version2025r3
LanguageEnglish
You can use scripting to create HTML pages that let you switch between views. HTML pages can be added to your views, so they appear together with video from your cameras.
Example: In an HTML page, you can insert a clickable floor plan of a building that allows operators to simply click a part of the floor plan to instantly switch to a view that displays video from that part of the building.
sidebar. Requirements
If your XProtect VMS system supports Smart Client profiles, you must enable HTML scripting on the required Smart Client profiles in XProtect Management Client.
If your XProtect VMS system does not support Smart Client profiles, you must enable HTML scripting in the Client.exe.config file.
