Remove playback restrictions
Version2025r3
LanguageEnglish
You cannot remove multiple playback restrictions at the same time. You must select and remove one playback restriction at a time.
  1. In Live or Playback mode, click Video restrictions > View to open the Video restrictions list dialog.
  2. In the Video restrictions list, use the filters and search field to locate the restrictions you want to remove.
    Live restrictions are displayed at the top of the list and each live restriction is marked with a green LIVE icon.
    Playback restrictions are displayed under the live restrictions.
  3. Select the playback restriction you want to remove and click Remove to open the Remove playback restriction dialog.
  4. In the Remove playback restriction dialog, click Remove restrictions to remove the selected playback restriction and open the Delete playback restriction dialog.
  5. In the Delete playback restriction dialog, click Close when the removal process is done.
    Click Details to get a more detailed overview of the removal status.
