Pause rule-based or manual patrolling sessions
Version2025r3
LanguageEnglish
If the system administrator has given you PTZ priority permissions, you can pause rule-based patrolling sessions or manual patrolling sessions started by other users.
You can pause a patrolling session if you have a higher PTZ priority than the user or rule currently controlling the camera.
  1. In live mode, select the view item with the relevant PTZ camera.
  2. Select Pause patrolling.
    Pause patrolling in XProtect Smart Client.
    The PTZ icon turns green for you and red for all other XProtect Smart Client users.
    Note
    Patrolling is no longer paused if you pan, tilt, or zoom with the camera.
  3. To resume the rule-based patrolling again or free the camera so other users can control it, select Pause patrolling.
