OpenStreetMap tile server
Version2025r3
LanguageEnglish
If you use OpenStreetMap as the geographic background for your smart map, you need to specify a tile server. You can specify a local tile server, for example if your organization has its own maps for areas such as airports or harbors, or you can use a commercial tile server.
Note
To use a local tile server, you do not need internet access.
The tile server address can be specified in two ways:
  • In XProtect Management Client - you set the tile server address on the Smart Client profiles. The server address applies to all XProtect Smart Client users assigned to the Smart Client profiles
  • In XProtect Smart Client - you set the tile server address in the Settings dialog. The server address applies only to that installation
