Motion search thresholds
Version2025r3
LanguageEnglish
When you search for motion in selected areas of a camera, you can adjust the motion threshold. The motion threshold determines how sensitive the motion search mechanism is:
  • The higher the threshold, the more motion is required to activate motion detection. Likely, this will produce fewer search results
  • The lower the threshold, the less motion is required to activate motion detection. Likely, this will produce more search results
