Map settings
Last Updated: 3 minute read
Version2025r3
LanguageEnglish
In setup mode, you can use the Properties pane to adjust a number of settings for individual maps.
Name
Description
Home map
Displays the map that forms the basis of the particular map view. The field is read-only, but you can change the map by clicking the selection button SC_Map_SetupMap_icon.png to open the Set up map window.
Rename map
Edit the name of your map.
Change background
Change the map, but keep the elements on the map in their relative positions to each other.
Icon size
The Icon size drop-down list lets you select the size of new elements added to the map, ranging from Tiny to Very large. You can re-size icons on the map by pulling the sizing handles in the corners of the icons.
Show name
The Name check box lets you enable/disable whether names of elements are displayed when adding new elements.
Tip
If you have added an element to the map and the element name is not displayed on the map, right-click the required element and select Name. If you do not want the element name displayed, right-click the name and select Delete text. Icon size drop-down list lets you select the size of new elements added to the map, ranging from Tiny to Very large. You can re-size icons on the map by pulling the sizing handles in the corners of the icons.
Allow pan & zoom
Select to allow pan and zoom on the map in live mode.
Auto maximize map
Select to automatically maximize the map to full screen in Live mode when the XProtect Smart Client has not been used for the number of seconds defined in Timeout. The maximum number of timeout seconds is 99999.
On mouse over
Select to display a live video preview when you move the mouse over a camera.
Use default display settings
Select to define that the preview window looks the same as your other views. Clearing this checkbox lets you define the Title bar and Live indicator settings for previews.
Title bar: select to display a title bar with the name of the camera.
Live indicator: select to display the indicator for live video, which flashes green when the image is updated. See View the status of live video. You can only select Live indicator if you have also selected Title bar.
Status visualization
Select to graphically display the status of the elements added to a map. See View status details on maps.
Enable status details support
When selected, you can see status details on cameras and servers in live and playback mode.
Automatically change map on alarm
Select to automatically change the map in the preview when you select an alarm to display the map for the camera that the alarm relates to.
Only show on hover
Select to only show camera view zones and PTZ presets when you move your mouse over the camera, view zone or preset. This setting is useful if you have several cameras on a map with overlapping view zones or several presets. The default value is to show view zones and presets.
