Managing your searches
Version2025r3
LanguageEnglish
Note
This feature is only available in certain XProtect VMS systems. For more information, see: Milestone XProtect® Product Comparison Tool.
You can save your searches to reuse them and share them with others. Depending on your user permissions, you can also access and use the searches made by others, unless they are private. When a search has been saved, you can:
  • Change the name and description, and make the search private or public.
  • Modify how the search is configured, for example, by adding or removing cameras or by adjusting the search categories.
  • Delete the searches as they become obsolete.
