Log into access control systems
Version2025r3
LanguageEnglish
If your organization has an access control system, you can be asked for additional login credentials when you log into XProtect Smart Client.
  • In the log in window for your access control system, enter your login credentials.
If you don’t know your login credentials for your access control system, contact your supervisor or system administrator.
