Lock to selected audio devices
Version2025r3
LanguageEnglish
When you select a camera view item in a view, the audio devices attached to the camera are also selected. You can listen to audio from the camera and broadcast audio to it.
In some situations, you might want to listen to and broadcast audio from one specific camera while viewing video from other views and cameras.
Example: You need to listen and talk to a crime victim through the microphone and speaker attached to camera A. At the same time, you need to view video from cameras X, Y, and Z in other views to follow the criminal’s whereabouts.
  1. On the Audio pane, select the relevant microphone and speaker.
  2. Select Lock to selected audio devices.
  3. Remember to clear Lock to selected audio devices again when the incident is solved.
