Ignore alarms on maps
Version2025r3
LanguageEnglish
On a map, you can ignore an alarm for an element for a duration of time. For example, if a camera is being repaired and therefore disconnected, you might want to ignore the error showing up on the map during the repair. When you ignore an alarm on a map, this does not remove the alarm from the alarm list, just the map.
Ignore alarms on maps in XProtect Smart Client.
