Hardware acceleration advantages and requirements
Version2025r3
LanguageEnglish
Hardware acceleration improves the decoding capability and performance of the computer running XProtect Smart Client. This is particularly useful when you view multiple video streams with high frame rate and high resolution.
Note
XProtect Smart Client supports hardware accelerated decoding using Intel® and NVIDIA® GPUs. Milestone does not recommend the use of Scalable Link Interface (SLI) configuration of your NVIDIA display adapters.
You can only use hardware acceleration with the operating systems Microsoft® Windows® 10 (build 1809), Windows® Server 2016 or later versions.
Note
Only non-virtual environments are supported.
